11-22-2004, 08:43 PM   #1 (permalink)
machtang
brakes on a 82 t-bird
i am working on a 1982 t-bird and the brakes are spunggy. What is the problem? How do i fix it? can you guys help?[img]/phpBB/images/smiles/icon_bow.gif[/img][img]/phpBB/images/smiles/icon_bow.gif[/img][img]/phpBB/images/smiles/icon_bow.gif[/img]
machtang is offline   Reply With Quote
11-22-2004, 08:58 PM   #2 (permalink)
CaptVirgilHilts
Well spongey[img]/phpBB/images/smiles/icon_spongebob.gif[/img] usually means air in the system as air is much more compressible than liquid ( brake fluid) Other problems would be the rear drums might be out of adjustment which would cause more pedal travel that might feel a bit spongey [img]/phpBB/images/smiles/icon_spongebob.gif[/img] regardless a full inspection for leaks and general condition including all hardware like sliders and springs etc. would be in order. It may do you well to bleed the entire system too. A poor pedal can also mean a bad master especially if it leaks down. HTH Stu
11-23-2004, 12:34 AM   #3 (permalink)
fogged408w
Before you go replacing stuff... since its an 82 I'd bleed all the old fluid out and fill it with new first.
