12-13-2004, 01:49 AM   #1 (permalink)
galaxierace
problems with 69 mustang
351w fmx trans. Starts-idles just fine, drop it into gear and it sputters and acts like it wants to die untill you give it gas, then it drives like a bat outta hell, that is till you slow to a stop light were it wants to die again.???? What could this be?
galaxierace is offline   Reply With Quote
12-13-2004, 02:28 AM   #2 (permalink)
Cyclone Joe
Vacuum leak maybe? Check all of your vacuum lines for crack. You can also use a can of quick start at the vacuum ports to see if they're leaking around them also. Check the simple stuff first.
Cyclone Joe is offline   Reply With Quote
12-13-2004, 07:36 AM   #3 (permalink)
63Kcode
Yep, sounds like a vacume leak to me
63Kcode is offline   Reply With Quote
12-15-2004, 04:13 AM   #4 (permalink)
galaxierace
i will check for vaccume leaks. thanks
Probe Industries
