12-31-2004, 03:38 PM   #1 (permalink)
Falconinpa
pistons
Does anyone know if 5.0 (roller cam, late 80's Mustang) pistons/ rods work in a '69 block/'69 crank/'69 heads(stock) 302? Balancing issues, compression ratio, valve-to-piston clearance are what I'm wondering about. Thanks for any help.
Falconinpa is offline   Reply With Quote
12-31-2004, 07:49 PM   #2 (permalink)
Nastystang
pistons
Dont know a lot about the answer, but I do know the back of a late mdel crank is machined for a 1 piece seal and I think the rear main is different because of that.[img]/phpBB/images/smiles/icon_confused.gif[/img]
12-31-2004, 11:15 PM   #3 (permalink)
mavman
pistons
Not real positive, but I would say yes...as long as the donor isn't an '86 that has those bastard E6SE heads. they have true flat tops with no valve reliefs.
12-31-2004, 11:52 PM   #4 (permalink)
Falconinpa
pistons
The pistons are E7's, so they're newer than '86's. Yes, these have valve reliefs. Just thought maybe we could gain a little compression over the stock '68 dished pistons. I already have a couple sets of those E7's, not much $$$ to just buy new, besides I've got to spring for a new crank kit for the '68 block, and already have everything else for it. Someones got to build the junkyard dogs out here.
12-31-2004, 11:56 PM   #5 (permalink)
mavman
pistons
you may want to have it balanced as the later model rods (from what I've seen) are lighter at the big end than early rods. Other than that, I don't see any problems[img]/phpBB/images/smiles/icon_tup.gif[/img]
Lakewood
