01-02-2005, 06:40 PM   #1 (permalink)
alanmacdougall
AFR205 Valve Spring Selection - Which Spring Pressure?
The AFR205's wll go be going on my 408W. I have a custom hydraulic roller cam with .581 max lift. Along with my new heads, I ended up with two sets of AFR valve springs. The spring specs are as follows.
- Seat Pressure: 170#, open pressure 445#
- Seat Pressure: 140#, open pressure 378#
I don't want any valve float below 6200+ rpm. I have some concern that the Crane tie bar type hydraulic roller lifters could collapse with the heavier springs. What springs should I use and why?
alanmacdougall is offline   Reply With Quote
01-02-2005, 07:14 PM   #2 (permalink)
ville
Even the smaller springs will do with 6200 rpm.Just remember to use minimum amount ( 1/6) turn of lifter preload to minimize valve float. I revved my hydraulic roller lifters to 6500 with AFR 185s 120 lbs springs and 1/6 turn.
ville is offline   Reply With Quote
01-02-2005, 10:12 PM   #3 (permalink)
66Fstbk
I have a set of AFR205s that I was going to have set up by my machine shop for a hydraulic roller and the specs they were going to use were 135# seat and 370# open pressures. Max RPMs the engine would see was 6500. Lift was similar to yours.
450# seems a little high.
66Fstbk is offline   Reply With Quote
01-04-2005, 02:07 AM   #4 (permalink)
alanmacdougall
I also think the 140# springs would be fine. The guy that designed my custom cam said that he would use the 170# springs. He seems to beleive that a spring under 400# open pressure may have valve float.
Ville: at what RPM did you power start to fall off? Thanks for the input.
01-04-2005, 03:49 AM   #5 (permalink)
fogged408w
I'm running a TFS 24? duration .591 lift hyd roller with 130 seat in my 302. stock holley systemax springs.
what are you cam specs at .02 .05 and advertised?
01-04-2005, 04:13 AM   #6 (permalink)
f100cleveland
I'm running a PSI brand spring with my hyd roller that has 0.640" lift. The springs have about 155-160# installed height and about 450# open. I shift mine at about 7100 RPMs and haven't had a valve float problem. But I'm running titanium retainers. Also, I'm running the bigger Cleveland 4v valves, so there is more weight to be tossed around. I would go with the 140# springs.
f100cleveland is offline   Reply With Quote
01-04-2005, 07:53 PM   #7 (permalink)
alanmacdougall
I will definitely put the 140# springs in. Thanks
