01-05-2005, 02:59 PM   #1 (permalink)
HankyJ
Why Destroke an Engine?
I know why people stroke engines, and even why they choose not to. But why in the world does someone want to destroke an engine? I see this mentioned in articles about race cars quite a bit. Is it just to comply with cubic inches rules, or is there a mechanical benefit to it? [img]/phpBB/images/smiles/icon_confused.gif[/img]
01-05-2005, 03:17 PM   #2 (permalink)
gork1rogues
From what I understand it allows for higher revving capabilities.
01-05-2005, 04:08 PM   #3 (permalink)
rbohm
[img]/phpBB/images/smiles/icon_cool.gif[/img]one reason is to meet class rules, another is to gain a better rod/stroke ratio, with attendant advantages and disadvantages. a third reason is to prevent and engine that is built right at class displacement allowances from growing to break the displacement rules. most engines will grow an inch to an inch and a half in displacement when they get hot, so you reduce the stroke a bit, usually a couple of tenths, so that when the engine grows, it meets class requirements.
01-05-2005, 04:59 PM   #4 (permalink)
HankyJ
Very interesting. Does the different rod ratio allow for higher revving as well?
01-05-2005, 05:21 PM   #5 (permalink)
Beoweolf
What about valve size to piston surface area? given the same bore, but a shorter stroke; it seems logical that you would get better cylinder filling with a shorter stroked engine vs. one with the same bore and a longer stroke.
The concept goes a long way to explaine what an engine like the 289/302 is so very close to the same horsepower of much larger engines. Obviously the longer stoke engine will reach its horsepower and torque peak earlier. Butthat isn't the point. Strictly speaking of horsepower, a smaller engine, built right, should have a higher horsepower potential (cubic inch to cubic in) given the same valve sizes/restrictions.
Better breathing equals better volumetric efficency. This is a case were...given limits on head design, valve sizes. number of valves...smaller might not only be more efficent...it could actually be better.
Any one remeber the 350 Olds engines of the 60's and 70's? They were street terrors, more so than the larger 400-455.
01-05-2005, 05:31 PM   #6 (permalink)
R Code
I'm no expert, but I am under the impression that the circle track guys dealing with say 358ci limits might have different bore/stroke combos for different tracks. Shorter stroke/bigger bore is more of a top end combo with the opposite combo being better for a torque (shorter) track.
Also, talked with a machinist/engine builder who put together a de-stroked motor for a land speed record holder dealing with a ci limit. He did a long-rod combo and destroked the motor to make a peaky, top-end motor. I don't recall the displacement goal, but it was small for a domestic V8, so he destroked an sbc...
01-05-2005, 05:41 PM   #7 (permalink)
n2omike
Especially back in the old days, the cylinder heads were the main restriction when it came to making horsepower.
Most stock heads did well to properly feed small engines... let alone larger ones. Larger engines would be 'wheezing out' by the time they hit very many rpms.
If you needed more top end than low end... which was the case for most with the crappy tires and suspensions of the day, you could de-stroke an engine and trade off some of that unneeded low end grunt for top end horsepower!
I top-end raced a 421ci small block Camaro on the interstate once (no bottle). We were close at first, but his big inch motor started to wheeze out of cylinder head around 130mph... and I was able to walk right past him. He was pissed and confused, and his friends made fun of him. [img]/phpBB/images/smiles/icon_smile.gif[/img]
I don't do that stuff anymore.
01-05-2005, 06:09 PM   #8 (permalink)
HankyJ
Okay, it's starting to make sense. It's why I only see destroked race engines and not street destrokers. Is that what they'd call it, "a destroker"? If not, they should.
Mike, I'm glad you embarassed that Camaro guy in front of his friends. It's our job.
01-05-2005, 08:40 PM   #9 (permalink)
clevelandstyle
A use to do a lot of dirt drag racing. It was 4x4s on a 300ft dirt track. Otherwise it was just like racing on asfalt. We did bracket racing and class racing. Many guys would have 2 engines. A big bracket motor and a small class motor. The classes were based on a weight per cubic inch ratio so the smaller engines had the advantage. Many guys ran 283, 302 and 327 chevies. The ford guys ran 289 and 302 fords. Some were more exotic "destrokers" like 351 Clevelands destroked to just over 300. Some Chevies were destrokers 350s and 400s with 283 and 302 cranks. It was and still is rare to see a big engine in a class being competitive.
In a weight/cubic inch race the smaller engines don't really make more power than big engines. The advantage is in the fact that they can carry less weight.
01-05-2005, 10:32 PM   #10 (permalink)
mavman
Built a 353 SBC once with a 400 bore and 327 crank with main spacers. Been a while back and I don't remember all the details, but the guy that ran it loved it. Great little engine, too bad the GM cranks are total junk..even the "steel" cranks. I bet most don't know that a 429 Ford is basically a "destroker" 460. Same block, bore, rods...pistons are a bit different and the stroke is shorter. Same with several other makes of engines. 400 Mopar is basically a .020" over 440 with the short stroke of a 383. Weird how Chrysler thought that the 400 should have a larger bore than the 440?!
There was an article written in National Dragster a while back dealing with extreme RPM of the Pro Stock classes. 10,000 RPM is now the norm where it was once un-heard of not too many years ago. Advantage of higher RPM is that you can run more rear gear which gives you greater mechanical advantage, which gets the car moving quicker....not necessarily faster, but quicker. Quicker=better ET.
<font size=-1>[ This Message was edited by: mavman on 1/6/05 9:34am ]</font>
<font size=-1>[ This Message was edited by: mavman on 1/6/05 9:35am ]</font>
