Duraspark and 12 volts?
I will be wiring up the duraspark on my 65 F100 this weekend. The truck doesn't seem to have a resistor wire coming from the switch, I'm pretty sure its 12 volts going to the ignition. If it is 12v, do I need to use a ballast resistor to knock it down a few volts? Will the duraspark box burn up if it runs at 12V all the time?
The truck had been running on the duraspark before I started restoring it and it had a resistor, now I'm putting it back together. Problem is, I can't find a way to hide the resistor anywhere, I'm trying to keep all wires and stuff hidden. If I have to use a resistor, I guess I'll find somewhere to put it...
