Timing Set / Cover Fitment Problem
yes, I've seen that numerous times. I don't use a fuel pump eccentric though on any of the race cars, but I did run into that problem on the junkystang that does use one. Some cam gears are thicker than others, and I believe that is why the eccentric hits the cover. You theoretically "could" machine the eccentric, but the fuel pump lever may hit the cam gear. I would pull the eccentric, install the cover and fuel pump and make sure the gear doesn't hit the lever before you go machining the eccentric. Either that or you could go with a different timing set.
