02-14-2005, 10:52 PM   #1 (permalink)
thyde
Dual Point Distributor rebuild
I trying to find a source of Ford dual point distributor parts and/or rebuilding house to restore my dual point. I seem to remeber reading an article in Mustang Monthly that referenced a shop that did that work but I can't find it.
Can anyone help?
thyde is offline   Reply With Quote
02-15-2005, 03:39 AM   #2 (permalink)
fogged408w
unless this rebuild is for a "correct" restoration, your better off with an electronic distributor. Any napa or other auto place should have a points kit for it. What king of parts is your dizzy missing? Is it complete but just old?
Here is a link on setting your points.
http://www.centuryperformance.com/point_settings.asp
02-15-2005, 11:04 AM   #3 (permalink)
71Marquis
Hey, massaging points is an art! Both of my 429 Mercs are running single-point setups, but I've been thinking of converting one of them to duals also. By the way, while they cost a few bucks more, I've found the Accel points seem to make for more precise high-RPM firing with their heavier spring.
From what I've heard, duals are trickier to dial in but the way I see it is you can squeeze more juice out of the coil while using period-correct technology. Last time I checked, Obsolete Ford Parts (http://www.obsoletefordparts.com) had conversion kits (plate, points, etc.) for around $40 or so. The easy way out would be to use one of those Pertronix electronic conversion kits but I'd say stick with points...
71Marquis is offline   Reply With Quote
02-15-2005, 11:44 AM   #4 (permalink)
F15Falcon
Keep the points, and hook up an MSD 6AL to it and you will have an awesome spark, but if the box ever takes a crap you can get home on points alone. The dizzy will now tell the box when to fire, and they will carry very little voltage and they will last a very long time. I have points on all my cars, including my race car, and they do not miss a beat.
