04-01-2005, 01:27 PM   #1 (permalink)
strtcar
A little tunning help please
Okay today was the first day i could take my car out more than just around the block after my winter cam swap. I put a comp cams xtreme engergy 262h cam, air-gap intake, and 650dp on my 289. I have noticed it weak/breaking up between 1500-2500 rpm, after that it really picks up pretty good. What do you guys thing this can be, below is a list of specs/parts
262h cam
pertronix
650dp 65/68 jets 6.5pv
15 in vacuum at idle
base timing 12* advance 32 all in by 2500
I'm not sure if its a lean issue, should the secondary squirters squirt fuel when the car is in park and I rev it? Here is a picture of my plugs, 45-50mph crusing for about 20 mins.
http://www.fordmuscle.com/pics/strtcar_plug.jpg
Any information would be great thanks
Richard
04-01-2005, 02:56 PM   #2 (permalink)
ujt389
I had a simular problem and it was due to an accelerator pump squirter bieng clogged.
04-01-2005, 03:07 PM   #3 (permalink)
Joe30690
I had a similar problem and my car responded to bigger squirters.
Joe30690 is offline   Reply With Quote
