04-03-2005, 08:56 PM   #1 (permalink)
tirefryer
9 inch rearend question
i have a 28 spline case can i put a 31 spline spool in it?
i was thinking if i had the correct bearings it would fit.
thanks
tirefryer is offline   Reply With Quote
04-03-2005, 09:07 PM   #2 (permalink)
F15Falcon
If it is a mini-spool, it will fit, but the case may have to be opened up to fit 31 spline axles in it if it is a 28 spline case, and by case I mean the part where the ring gear bolts.
04-03-2005, 09:17 PM   #3 (permalink)
ckelly
I run 31 spline axles in a small bearing (2.89) "28 spline" case. 28 or 31 spool should fit as long as it's made for the bearings.
1967 Falcon 4 door w/351C - Owner built, owner abused.
70 Mustang 302 / 02 Mustang V6 rag top, 04 SuperCrew parts hauler
http://raceabilene.com/kelly/hotrod
<font size=-1>[ This Message was edited by: ckelly on 4/4/05 9:18am ]</font>
