04-18-2005, 03:22 AM
XolieX
when 460 is hot, doesn\'t want to start back up on shut-down...vapor lock/start heat soak?
well when the 460 runs for a while and you turn it off and want to turn it back on. it won't until it cools down for a long enough period of time.
i came into conclusion in a post 9 months ago it would be the starter getting hot. just to make sure its that, i just came to think it may also be a vapor lock. however, i don't have the fuel lines near exhaust.
what are some things i should check for? i would hate to be driving off being cool on weekends and not be able to start up my car again until it cools down.
04-18-2005, 03:37 AM
fastbigblockford
i had one that acted about like what you are describing, found out it was actually the timing chain that was causing the issue, not saying thats your problem but it is an idea.
later
04-18-2005, 06:39 AM
dadurweird
Something is geting too hot. Check your fuel system from the gas tank to the carberator, if any part of the line is too close to a heat source, you may have a vapor lock issue.
Does your engine turn over at a normal speed when you try to start it? If your engine cranks slow, then look at your starter heating up from headers/exhaust pipes.
Look into your ignition wiring to make sure connections are correct and making good contact, so no componant is getting too hot, peventing starting.
04-18-2005, 01:55 PM
XolieX
well i got all good connections and new wires. however i do only got 2 smallish wires for grounds for chassis to block.
the starter really isn't relaly that close to exhaust. i cna change the starter out real easay. and yes when i try starting it when its hot, all it does is just turn once then die. doesn't do anything else.
i just got feeling if its vapor lock then the motor will still crank. not the case here.
so i'm dead on the starter soak problem. is there something at a hardware place like home depot or something to get a shield? i know you can get metal straps at home depot.
04-18-2005, 03:25 PM
HankyJ
I've seen numerous guys (Ch**y guys mostly) who have made their own shield out of aluminum and on both sides put a bit of heat proofing material. It should be an easy fix. It sounds to me that you have heat soak also, not vapor lock. Vapor lock tends to show itself while driving as well.
04-18-2005, 05:29 PM
dadurweird
You may want to run larger cables to and from the battery. The larger the cables, the more juice the cables will carry. If your engine is turning over slowly, less power goes to the ignition system, your engine will not fire.
Keep in mind the large size of the 460 (not in CI, but in how big your engine is) inside the engine compartment. The engine will hold a lot of heat after shut down and radiate the heat to the starter.
Check all of your grounds and connections. Grease and dirt transfered from your hands may interfere with the power to and from the starter.
04-18-2005, 05:57 PM
5851a
Mine did the same thing untill I threw away the delco type starter and bolted one from a 351M.
04-18-2005, 09:20 PM
jeremyl
My Galaxie does that too. On mine it's a heat soak situation with the starter since I've got 3 inch pipe right in that area. I'm gonna put a nippondenso style PMGR starter on mine which will solve it. Also I'd upgrade the wire from the battery -> solenoid ->s starter & also run a comparable sized ground. Go with 4 gauge wire with a good strand count & use good ends. If you've got a local starter & alternator place close by most of them stock stuff to make cables. If your battery is in the trunk then go with an even large wire such as 2 gauge or even 1/0 gauge.
04-18-2005, 09:49 PM
#9 (permalink)
thekingofazle
remember that once the engine is warm the clearances tighen up - crank, pistons, rods, cam, valves, everything.
When you let the engine get hot, if the starter is already barely getting the engine to turn over, adding that resistance because clearances have shrunk makes it that much harder to turn over - which, coupled with the heat soak, could be putting your starter over the line.
You might try another starter, just for kicks.
04-19-2005, 01:00 AM
#10 (permalink)
frdnut
Had the same problem with my 429 thunderjet in the summer time(installed in my 1982 pickup).I was able to cure it by getting a big powerful battery (1000CCA) and using the heaviest gauge cables I could find.
