04-18-2005, 10:54 PM   #1 (permalink)
igo1090
1993 5.0 mustang questions
i know mostly the older ford stuff. need to help a friend get 400 hp on a rebuild. is this engine efi (didnt look at engine yet.).? roller cam?, mass air sensor? i was thinking edelbrock heads, better cam, 331 stroker, larger injectors (assuming efi & mass air), shortie headers. anyone have any other thoughts?
all help appreciated.
thanx
igo1090 is offline   Reply With Quote
04-18-2005, 11:25 PM   #2 (permalink)
2FST4U
http://carcraft.com/techarticles/116_0307_ford/
2FST4U is offline   Reply With Quote
04-19-2005, 01:43 PM   #3 (permalink)
87stang
400 fly wheel HP?
For your first question, in stock trim the '93 5.0 is EFI (w/MAS), has a roller cam, and hyper. pistons.
The easiest (and probably cheaper) way to make the power is with a power adder...either supercharger or turbo. Even then you might need to consider some induction changes.
Going NA, a 331 stroker kit, AFR heads, Holley SysteMax or Edelbrock Performer RPM intake, and a custom cam should get you in the neighborhood too. All the other supporting items as well: MAS, injectors, CAI, full exhaust, a custom tune, etc.
Don't forget to consider drivetrain upgrades to handle such a large increase in output.
