351c-2v and oil pump shaft install
**Only use this method if you absolutely have to -- Engine already in car, etc **
Clean out the end of the distributor shaft and the oil pump drive with carb cleaner.
Then cram a load of RTV into the bottom of the distributor shaft.
Stick the oil pump drive shaft up there and let it dry.
Now you can stab the distributor and the oil pump shaft at the same time.
If the engine is just sitting on the stand, take off the oil pan and do it right. It'll cost 15 bucks in gaskets, but it'll be worth it.
Greg
'71 Torino GT 466/C6
11.3:1, Edelbrock CJ RPM heads, 250/262 @ .050 solid flat tappet, CJ Stealth, 850 DP, Hooker 6115 headers, TCI streetfighter, C6, 3.89 31 spline trak-lok. [img] <a href=[/img]http://www.fordmuscle.com/readerscars/showpic.php?id=963</a> " BORDER="0" WIDTH="200" HEIGHT="100">
<font size=-1>[ This Message was edited by: GregP on 4/27/05 11:07pm ]</font>
