05-02-2005, 09:07 PM   #1 (permalink)
elsanyo
c6 vacuum modulator
Replacing my modulator because I found fluid leaking out of hose. My question is , which way do I adjust it ? Some say three turns out ,others say turn in one turn ,who is right ,and what way is everyone else running there's
elsanyo is offline   Reply With Quote
05-02-2005, 09:50 PM   #2 (permalink)
Gent
c6 vacuum modulator
You can run it as is for a basepoint, turn in if slightly later and firmer shift are desired and out for earlier softer shifts
Gent is offline   Reply With Quote
05-02-2005, 10:39 PM   #3 (permalink)
elsanyo
c6 vacuum modulator
approx.how many turns in for firmer shifts
05-03-2005, 10:24 PM   #4 (permalink)
Gent
c6 vacuum modulator
3 turns +- depending on where the adjustment screw is, if it is flush with the vac outlet you should be able to go 3 to 4 turns in, if you need any later or firmer shift than that will produce then you will have to go into the v/b and or governor.
