Final Gear Ratio
With 'mustang' sized tires, I really liked the 3.25's if I had a lot of highway driving to do. It's a good overall gear ratio to be used behind a trans that has no overdrive. 3.55's really seemed to hold the car back on the freeway.
Sure, if you just want to play around town or go to the races, install a 4.11 or something...
My advice would be to install the 3.25's if you do much highway driving, and start gathering parts to build a 4.11 or 4.30 for track use. Once you have it built, it's really easy to swap em' back and forth. [img]/phpBB/images/smiles/icon_wink.gif[/img]
I use to drive 3hrs to the track with 3.25's, switch to the racing gear once I got there, then switch back for the drive home.
Good Luck!
