Strange 66 289 misfire
Hi, I have a 66 Mustang with a 66 289 with a mild cam, 4 barrel edelbrock 600 tri Ys dual exhaust and a C-4 auto. I just fired her up a couple of weeks ago to get er ready for the season and the car was running fine. I took it out for a ride and it ran strong but when I got home it started missing at an idle. I just shrugged it off and bought a set of pertronix wires and autolite plugs. I started the car up today and it would barely stay running, so I decided to change the plugs and wires. well needless to say the car runs like poop now. Its missing horribly. I pulled each plug wire and came up with this, cylinders 2,3,5,8 make absolutly no difference(not firing), I could pull em off and it would run the same. I have spark coming outta the cap and I haved tried another set of wires and plugs but it runs the same, I have also checked my timing and rotor and distributor cap, all is new and in good shape. Now!! The strange thing is that if I revv the car up slowly it will be missing like crazy then all of a sudden whammo!! the idle jumps up and she roars like nothing is wrong, but if I hold the throttle there you can hear stumbling a little still then when I drop the idle down it goes back to idleing like poop again. I figured I would pick your brains before I pull the valve covers and start digging into the engine mechanical I.E. lifters/valves. Oh yea and I did a compression check and its about 150lbs per cylinder. What do you guys think???
Thanks, Jack
