05-25-2005, 07:46 PM   #1 (permalink)
alanmacdougall
coil spring compressor
I rented a spring compressor from autozone to take my front springs off. The tool has a fork that supports the upper coil with the screw going through it to the lower support with the the two swing away claps that go on the lower coil. I took one spring off, but for some reason I am nervous to use this tool to put the spring back on. Do you guys have any other tools that you could recommend? I only have one life and don't want to end it any time soon.
alanmacdougall is offline   Reply With Quote
05-25-2005, 08:10 PM   #2 (permalink)
deleted2
I've used that tool for years, no problems... & I do big block stuff [img]/phpBB/images/smiles/icon_smile.gif[/img]
05-25-2005, 08:18 PM   #3 (permalink)
alanmacdougall
do you leave the upper contol arm attached to the shock tower when you install the springs?
05-25-2005, 09:11 PM   #4 (permalink)
alanmacdougall
one is in, one more to go. thanks
