05-29-2005, 12:03 AM   #1 (permalink)
FoMoCo
Driveshaft
When in park and tires on the ground how many degrees should you be able to turn a driveshaft by hand back and forth? Mine seems like alot on the c6/9" locker.
05-29-2005, 12:12 AM   #2 (permalink)
Driveshaft
less than 3....
You should have very little play in the pinion gear. If you're talking about the play back and forth in park with the rear-end unbutoned from the driveline, there could actually be enough to move the car 5 or 7 inches (full travel length) and it's not going to be a problem...
