06-02-2005, 10:39 PM   #1 (permalink)
Kman
E7TE small block heads on C8OE block
Are there any problems using E7TE heads on a '68 302 block? It appears there is a difference where the coolant passage holes are on the block vs. the head???
Kman is offline   Reply With Quote
06-03-2005, 01:56 AM   #2 (permalink)
frenimy
I am using them on my 65 289 and they seem to be working fine other than an oil leak that I can't seem to get rid of. Make sure you plug all the holes in the rear of the heads or you will be sorry once you fire it up.
frenimy is offline   Reply With Quote
06-03-2005, 02:45 PM   #3 (permalink)
Kman
Yeah, I know about the Thermactor passages, got them plugged. Thanks for the info.
06-03-2005, 03:09 PM   #4 (permalink)
ckelly
I drilled holes in the GT-40's to match the gasket against the 65 block. Three, I think - not very big. Search on the topic and you'll find it.
06-04-2005, 07:14 AM   #5 (permalink)
dholroyd
Kman,
i have a set of 68 heads. all cleaned and valve job
all ready been done. heads are still in a bag. i also have
the block,but that need to be cleaned and honed. from
what i'm told. ford only made the 68 heads one year. i don't
know if they can be interchanged.
<font size=-1>[ This Message was edited by: dholroyd on 6/4/05 7:19pm ]</font>
dholroyd is offline   Reply With Quote
06-08-2006, 04:30 AM   #6 (permalink)
MoNaH302
Can someone give some more detail on matching the E7TE head to an older '68 302 block - I want to make this match this weekend.
blocking the rear holes on the head was mentioned - which holes? and with what?
What other issues might come up? rod lenght? bolt hole size?
Thanks!
MoNaH302 is offline   Reply With Quote
06-08-2006, 09:40 AM   #7 (permalink)
ckelly
http://www.fordmuscle.com/forums/all...ll+steam+holes
