4CYL to 390
Sell the 390 and score all the parts to swap in a 351W, which are as common as bad breath, and cheap to build (relatively speaking)
The extra 50 cubes make a big difference in power in a low dollar build (which this kinda sounds like) and it will mate up with most readily available transmissions.
You still need to upgrade springs, etc, but a good "TRW build" of a solid boneyard 351W core is an easy 275-325 (9.5 CR, 260 deg. cam, 650 carb, 1 5/8 headers) on the stock heads (with a tractable RV type street cam) much more with aftermarket heads and other sicko build goodies. That's the same as the 390, for less bucks and less weight.
Get a rear axle from a 5.0, and you're in business.
Good luck!
