I ported a set of '70 351w heads and wrote a post on the home porting forum on this site. In general, the heads were put on a 331 and i'm using a 282S Comp Cam (236 @ .050 and .528 gross lift). Horsepower (with full length dual 2.5" exhaust) is about 395 at the flywheel based on the last chassis dyno of 313 RWHP. I used 20% drivetrain loss for a C4 automatic and a 9" rear to derive flywheel HP. Open header flywheel HP is most likely over 400 and 410-415 if I were to venture an estimate. I'll be going to the drags this year so i'll see what she does.
So long as your not building a big cubic inch engine or a full out race engine, you can achieve a nice running street engine with ported 351w heads. Use the 69's...better than the later heads you have.
Tracy Blackford: Corona, Ca
'65 FB Mustang 331 with H-beam 289 rods, KB 322's, 282S cam, fully preped 351W heads. Built C4 and 3.50 9" posi
<font size=-1>[ This Message was edited by: blkfrd on 6/7/05 6:08am ]</font>
