06-07-2005, 02:38 PM   #1 (permalink)
torinoracer
80\'s mustangs
did they ever come with an efi setup but it looked like a carburetor setup, kinda like the chevy early fuel injection. or is this motor off something else. and i want to convert it to a carburetor setup, what is all need to complete this. Thanks for the help
torinoracer is offline   Reply With Quote
06-07-2005, 02:49 PM   #2 (permalink)
ChicoB
80\'s mustangs
There was a CFI setup in 1986 automatic 5.0s. Its basically similar to a GM TBI. It would just take a manifold swap to change to a carb. You might have to figure out a new ignition system too.
06-07-2005, 02:55 PM   #3 (permalink)
torinoracer
80\'s mustangs
why would a new ignition system need to be drawn up, are the cfi and ignition in correlation to each other and can it just be adjusted or would a new dizzy have to be installed
06-07-2005, 04:34 PM   #4 (permalink)
ckelly
80\'s mustangs
If it's a TFI dizzy, it's controlled by the computer. You'll need an ignition that's stand alone. You can't take an EFI car and just put a carb on it and leave everything else the same.
