\"Double Pumper vs. Standard\"
The DP has the capability of being faster, as long as the person running the go-pedal knows how much throttle the engine can handle at a given RPM. The VS takes the brain work out of it, but the secondaries aren't able to open as quickly as with a DP, so on a stick where you let off the throttle to shift and then get back in the throttle, the secondaries can take some time to open back up after the shift. On an automatic, where you just hold your foot to the floor, the slower opening secondaries aren't going to affect your ET much.
