06-29-2005, 06:44 PM   #1 (permalink)
Lupins
Compression ratio 1969 351w
Does anyone know off hand the stock compression ratio of a 1969 351w bored 30 over standard stroke 4barrell 69 heads with flat tops?
Thanks in advance
Lupins is offline   Reply With Quote
06-29-2005, 08:38 PM   #2 (permalink)
igo1090
stock bore was 10.7:1 factory rating.
igo1090 is offline   Reply With Quote
06-30-2005, 06:57 AM   #3 (permalink)
cobraii351
Just a bit of information.... There is no such thing as 351W 4V heads. The difference between the 4V motor and the 2V motor was flat top pistons vs. dished pistons.
cobraii351 is offline   Reply With Quote
06-30-2005, 07:32 PM   #4 (permalink)
Lupins
Thanks for the info.
06-30-2005, 11:02 PM   #5 (permalink)
htwheelz67
I'd say with milling etc.....the compression will be close to 11.1, a nice set of aluminum heads will cure that.
my 67 vert http://htwheelz.smugmug.com
htwheelz67 is offline   Reply With Quote
