08-19-2005, 02:58 PM   #1 (permalink)
fastranger
DRAG RACE QUESTION?
Do most of the racers run with no air cleaner?
fastranger is offline   Reply With Quote
08-19-2005, 03:25 PM   #2 (permalink)
outrgus
DRAG RACE QUESTION?
I would never run with out my air cleaner as it make no differnce in my 1/4 time, but i did pick up 2/10ths with a k&n extreme top.
outrgus is offline   Reply With Quote
08-19-2005, 04:26 PM   #3 (permalink)
fastranger
DRAG RACE QUESTION?
Thanks for the reply..
08-19-2005, 04:54 PM   #4 (permalink)
Hottarod
DRAG RACE QUESTION?
I run with no air cleaner on the strip. I have an air cleaner I keep on the carb at all other times. Once I forgot to take the air cleaner off and the car slowed down about a quarter of a second. My air filter is small and short and I also have a fresh air intake and the carb is jetted for no filter so it all adds up.
Hottarod is offline   Reply With Quote
08-19-2005, 08:17 PM   #5 (permalink)
19mach69
DRAG RACE QUESTION?
Theres a guy here who ran without a air cleaner. He was in the 10's. He lost control and sucked a huge amount of sand into his engine. He no longer runs 10's. Depends on how much risk you want to take.
19mach69 is offline   Reply With Quote
08-20-2005, 03:29 AM   #6 (permalink)
fogged408w
DRAG RACE QUESTION?
You should always run something to help straighten/curve the air down into the motor. That will make for a better signal to the boosters and more power. Now weather of not that includes a filter is up to you.
08-20-2005, 08:24 AM   #7 (permalink)
mavman
DRAG RACE QUESTION?
I don't have a way to put an air cleaner on mine.
08-20-2005, 01:43 PM   #8 (permalink)
EdwardS
DRAG RACE QUESTION?
No Filter, Ram air.
Then again, it's not a street car eithier.
EdwardS is offline   Reply With Quote
08-20-2005, 09:17 PM   #9 (permalink)
dacofa
DRAG RACE QUESTION?
K&N 14" air filter because the air needs to be smoothedout. Even when the air looks clean, there is lots of dirt and dust that will score your cylinder walls/rings.
08-20-2005, 11:45 PM   #10 (permalink)
thekingofazle
DRAG RACE QUESTION?
hmm - i was running 9.43's consistently (like 5 times in a row) then i took off the aircleaner and did a little timing tweaks - 9.16... mine is pretty restrictive though... its a drop base and the k&n filter isn't real tall...
