09-06-2005, 05:00 PM   #1 (permalink)
rancheroo
Holley Carb Question
I'm making my own fuel log, modeling it after a picture I saw in the latest Car Craft. On one of their supercharged engines (a rag-o-let), they have a couple of pieces of 3/8" tubing, running to both the primaty and secondary float bowls, supporting the fuel pressure regulator in the middle. Looks pretty good to me.
My question is: what angle are the fittings that screw into the Holley float bowls, 37 or 45 degree?
Thanks in advance, Rick
rancheroo is offline   Reply With Quote
09-06-2005, 06:19 PM   #2 (permalink)
Randall
45 degree. use a double flare.
<font size=-1>[ This Message was edited by: Randall on 9/7/05 6:20am ]</font>
Randall is offline   Reply With Quote
09-07-2005, 01:30 AM   #3 (permalink)
Crazy_garry
Yep, 45 degree.
Use a good double flaring kit that will give a good square flare, and if they leak don't torque the fittings real tight or you will screw up the fitting on the carb...ask me how I know
1964 Mercury Comet Caliente 2dr hardtop
302 roller block 0.030 over, '70 351W heads, HO cam, Hedmans, Ford 4 bbl intake, Holley 570 cfm, AOD, 8" w/3.08 open
<font size=-1>[ This Message was edited by: Crazy_garry on 9/7/05 1:30pm ]</font>
Crazy_garry is offline   Reply With Quote
09-07-2005, 05:03 AM   #4 (permalink)
mrlucky390
just a thought you can purchase a line already flared ,at both ends in different lengths from automotive aftermarket stores ,if you worry about flareing yourself ok just an idea bill [img]/phpBB/images/smiles/icon_confused.gif[/img]
mrlucky390 is offline   Reply With Quote
09-07-2005, 05:13 AM   #5 (permalink)
392Bird
I am using a off the shelf log, but using AN fittings and lines. The floats now have special AN fittings screwed into the floats, then braided lines and AN fittings. I am using a return system, so it has a return regulator mounted after the carb on the return line.
I am installing a fuel pressure guage in the center of the cowl hood opening now.
393 stroker
3,500 rpm converter
4.30 gears
17x9 Cobra Rs, with 255/45/17 front, 275/40/17 BFG DR rear
<font size=-1>[ This Message was edited by: 392Bird on 9/7/05 5:14pm ]</font>
392Bird is offline   Reply With Quote
