09-16-2005, 12:50 AM   #1 (permalink)
socal66coupe
Reverse Manual Valve Body
what is the bennifits of a Reverse Manual Valve Body on a c4 auto
socal66coupe is offline   Reply With Quote
09-16-2005, 02:50 AM   #2 (permalink)
ZephyrZ7
it can make things hydraulically stronger I hear but don't ask me to explain how.
09-16-2005, 07:12 AM   #3 (permalink)
wcj56
Removes the possabillity of hitting neutral when shifting to drive. It reverses the 123 so your shifting back towards yourself.
wcj56 is offline   Reply With Quote
09-16-2005, 01:55 PM   #4 (permalink)
igo1090
it will have higher line pressure which applies the piston in the drum harder for a faster shift and less slippage. also with no band apply in low, the shift is quicker also. the higher pressure can slightly slow up a low horsepower car, because it takes some hp to get the higher line pressure. i use one on the street and at the track and like the ultra firm shifts. shift kits dont come close.
igo1090 is offline   Reply With Quote
09-16-2005, 03:26 PM   #5 (permalink)
socal66coupe
well they said i dont have to change anything but the shifter to put the new valve body in do i realy need to get a hole new shifter set up
09-16-2005, 03:49 PM   #6 (permalink)
clevelandstyle
Well it depends on what kind of shifter you have. Most "ratchet" shifters work forward and reverse. Other gate shifters can still work by getting a new gate with the pattern reversed. You will have to call the manufacturer to see if this is an option.
A reverse pattern valve body has the fluid channels rerouted to bypass a lot of the valving that helps with a smooth shift. The factory channels are organized through valves, accumulators and orifices to "cusion" the shifts. A valve body with only a shift kit effectivly disables these "cusions" but the fluid still has to go the long way around. This can cause a bit of delay in shifting. A full manual reverse pattern valve body sends the fluid through the customized "short cut". This causes a hard quick shift that you just can't match with a shift kit.
09-17-2005, 02:32 PM   #7 (permalink)
tonys10sec306
The valve body will give you a very frim shift
