10-16-2005, 11:21 PM   #1 (permalink)
1965coupe
driveshaft
I want to change to a alum driveshaft on my 65 stang. I want something strong but liteweight. I would like to drop some of the driveline absorbsion and get more to the ground. what company and products are people using. want to know about u joint options thanks
1965coupe is offline   Reply With Quote
10-17-2005, 08:52 AM   #2 (permalink)
Hottarod
driveshaft
Hey I just did this on my 65 fastback. My drive shaft came from the salvage yard. I just tape measured my old shaft and went and found one that was the same length and fairly large in diameter. I took that and my yokes over to a local drive shaft shop and they put it all together and balanced it. My total investment was $175.
On a side note;
I weighed my parts and the aluminum shaft saved 4 pounds so I thought that was significant considering I sling the thing at 7000 rpms. In fact from what everybody has said it doesn't do much of anything as far as performance is concerned. The only advantage I got from all that was going to something that was stronger than the stock u-joints which were designed for a 6 cylinder falcon.
<font size=-1>[ This Message was edited by: Hottarod on 10/17/05 7:55pm ]</font>
Hottarod is offline   Reply With Quote
