11-24-2005, 06:39 PM   #1 (permalink)
smokey212
9\" third member help
Are the bearing caps for the carrier in the ford 9" the same size in the 28 and 31 spline setups. The reason I ask is b/c I had a busted cap on a 31 spline setup. I took a bearing cap off a 28 spline setup that I had laying around and it will not fit and the bearing race is smaller just by a little on the 28 spline unit.
smokey212 is offline   Reply With Quote
11-25-2005, 06:22 AM   #2 (permalink)
Just Strokin
Generally the 31 spline carried the 3.0625 bearing caps. Ford at one time offered a bearing called SlimLine for use in the 2.893 units for the 31 spline carriers. You will need to find a cap for the 3.06 bearing.
Larry............
96 Ford F350 PSD CC DRW
64 Fairlaine 500 rust bucket/future Tbolt clone with 501 BBF
<font size=-1>[ This Message was edited by: Just Strokin on 11/26/05 1:47am ]</font>
11-25-2005, 07:26 PM   #3 (permalink)
KENNETHL6
Rear end bearing caps are aligned bored to each individual case. Like an engine's main bearing or rod bearing, they are not interchangable. If you have a broken rear end cap, your case is likely a throw away.
KENNETHL6 is offline   Reply With Quote
Probe Industries
