rear disc brake line pressure?
Drums require more pressure. Discs require more volume, not necessarily more pressure. Most Ford master cylinders have a 2 step bore, one large bore for the front discs and a smaller rear bore for drums....but the smaller bore makes a spongy pedal and the calipers won't work as they're intended to.
I use a '79-'93 Dodge 1/2 ton pickup master cylinder. Had to cut/shorten the pushrod and drill the 5/16" mounting holes out to 3/8"...and make new fittings. Works way better than anything else I've used, including a high $$$ Wilwood M/C that was "supposed" to be the "one" for my setup...guy was wrong. The bias valve should be fine. I am still using my stock one that was set up for drum/drum.
