12-29-2005, 05:14 PM   #1 (permalink)
Freddie
Exhaust, Dual, X, H, ???
Building a 308 SBF. using Hooker long tubes with 3" exhaust.
Which would be the best way to go True dual, X, or H pipe???
Using a custom cam to make peak power around 7500RPM.
Looking for a little over 500HP.
Please explain reson for your choice.[img]/phpBB/images/smiles/icon_confused.gif[/img]
Freddie is offline   Reply With Quote
12-29-2005, 05:33 PM   #2 (permalink)
wcj56
At that high an rpm range the X pipe will be the best because of its ability to scavenge the tubes. H pipes work equally well at lower rpm ranges. Besides the X will make 7500 sound more like 10k rpm.
wcj56 is offline   Reply With Quote
12-29-2005, 06:58 PM   #3 (permalink)
wildosvt01
X!
No need to explain. Its an easy answer IMHO.
<font size=-1>[ This Message was edited by: wildosvt01 on 12/30/05 8:59am ]</font>
12-29-2005, 07:31 PM   #4 (permalink)
f100cleveland
I'll also recommend the 'X' pipe. You'll love the sound and the little bit of extra power you'll get.
f100cleveland is offline   Reply With Quote
12-29-2005, 07:54 PM   #5 (permalink)
dacofa
X pipe has proven time again to be the better setup. But not just any old setup. H pipe was alright in it's day, just old tech now. X pipe will cost you more and not many shops can do it. You can always get a good one and take it with you to have them install it.
12-29-2005, 08:11 PM   #6 (permalink)
thekingofazle
X! It makes it sound much smoother, and does give it a nice sound (not like bumblebee weedeater sound) but it makes the exhaust more pitched than stock... I love the way my car sounds with the X.
12-29-2005, 09:58 PM   #7 (permalink)
etcetera
Here's a good thread on the subject.
http://bbs.hardcore50.com/vbulletin/...highlight=pipe
To save the trouble of reading it, George Klass says the H-Pipe wins everytime on the dyno.
Eric
La Habra, CA
1964 Falcon Club Wagon - Bone Stock
1965 Econoline
408w SCAT crank, SCAT rods, Probe forged pistons, AFR205's, Comp Cams XR286R, Victor Jr, AED 950
<font size=-1>[ This Message was edited by: etcetera on 12/31/05 11:30am ]</font>
etcetera is offline   Reply With Quote
12-30-2005, 08:34 AM   #8 (permalink)
dbiscayne
They sound different for sure, other than that the H Pipe gives you a little more in the lower RPM's, the X Pipe takes over once the engine gets spinning fast, but the peak is usually only slightly higher than the H Pipe. So where do you want your power, hi or low?
dbiscayne is offline   Reply With Quote
12-30-2005, 09:55 AM   #9 (permalink)
Motorhead
I have yet to see a fair comparison between X and H. The only way to truly tell is to cut out the H, put in an X, leave EVERYTHING else in the exhaust system the same, and make sure the Air/fuel is still in check and get it back on the dyno. One comparison I saw compared full 2.5" H-pipe system to an X with 2.5" from the header to the X and 3" out of the X and the rest of the way back... who in their right ming would call that a fair comparison?
12-30-2005, 02:32 PM   #10 (permalink)
thekingofazle
I agree that H is old-tech. The X has all the benefits of the H with some of its own.
In effect, the X is an H, the gas just doesn't have to change direction as much to equalize. I mean, instead of having a separate tube to connect the exhaust pipes, the pipes are just brought closer so they touch and share a small bit of area.
With an H you have gasses that have to turn a 90 degree angle to see the other pipe. with an x, its effectively not much of a turn.
Probe Industries
