transmission
Yeah...what transmission?
If its the starter, test it by pulling it and using a break over bar to turn the crank by hand or push the car. If its still locked check the transmission.
If its an automatic, I'd wonder if you got the convertor fully seated. too often people will try to bolt the convert to the flexplate instead of seating the convertor in the transmission; then bolting the trans to the block and turning the convertor to match the bolt pattern, pull it forward and bolt it up.
The other possiblity, again on an auto, is the gear selector may be stuck in park.
Push come to shove... start over! pull the trans then check to see if the motor will turn over by hand. Then check the trans to see if you can spin the input shaft.
