01-21-2006, 11:24 AM   #1 (permalink)
Fomoco8
Idle air bleeds
I am trying to tune a Proform VS body matched to QUickfuel VS base plate, My screws were out 2 1/2 turns using a 67 bleed on the primary, Contacted QUickfuel they recommended a 61 , after putting them in I was only able to get a 1/2 turn back so I am still at 2 full turns out to get the best idle, Should i continue to drop bleed sizes or look for another problem? the carb is a solid cammed 460 .
IF it WON'T go,Make it BIGGER!
<font size=-1>[ This Message was edited by: Fomoco8 on 1/22/06 1:24am ]</font>
Fomoco8 is offline   Reply With Quote
01-21-2006, 04:06 PM   #2 (permalink)
xdclevo
Idle air bleeds
What problems are you having? If it runs fine, just leave it at 2 turns out.
I would of thought that increasing the fuel restrictor size in the metering block would enable you to shut the mixtures screws a bit more, if thats what you are after.
xdclevo is offline   Reply With Quote
