01-24-2006, 08:35 AM   #1 (permalink)
RollTide
couple of questions about RPM heads
Thinking about geting a set of the RPM heads with 1.90 valves. Was wondering for anyone that has used them what spark plugs do you use
do they require and special headers or header modification are there any hiding gremlins when swithching to them from stock heads.
Also can they be shaved to increase compression, they are 60 cc and current heads are 55cc
RollTide is offline   Reply With Quote
01-24-2006, 09:04 PM   #2 (permalink)
1QWIK64
The RPM heads use any standard header. I use Autolite #26 plugs in my Edelbrocks,but any equivalent will work. There is nothing but the usual issues when swapping. Of course you will need the appropriate rocker arm style depending on which head you buy. I would use a quality head gasket and head bolt set. If you are running a large cam and stock pistons , I would check v to p to make sure you have plenty. The heads can easily be milled down to 58cc. Hope this helps,Tim.
1QWIK64 is offline   Reply With Quote
01-25-2006, 04:34 AM   #3 (permalink)
tonys10sec306
any header will work
01-25-2006, 05:51 AM   #4 (permalink)
bmcd66250
I asked Edelbrock the same question about milling just two weeks ago. They told me they can safely be milled .065" and every .010' equals 1 cc.
bmcd66250 is offline   Reply With Quote
01-29-2006, 08:22 PM   #5 (permalink)
lfagan
I have the 2.02 RPM heads on my 306. Did run into a sparkplug to piston issue using TRW domes and there is little room for the #3 plug and boot with Hooker #6102 headers. I've cooked a few boots even while using the high temp sleeves.
-Len
lfagan is offline   Reply With Quote
01-29-2006, 09:04 PM   #6 (permalink)
gork1rogues
You mean 3926 tim?
01-29-2006, 09:35 PM   #7 (permalink)
dmbrummwtt
You will need head bolt bushings if you are putting them on a 289/302/5.0. The holes are drilled for 1/2" head bolts. No big deal, I got mine from Edelbrock along with new head bolts.
dmbrummwtt is offline   Reply With Quote
01-30-2006, 04:27 AM   #8 (permalink)
mstngjoe
I would suggest you cc the heads before & after if you decide to mill them.
I had a set of Performer heads that I milled .020 and still ended up with 60+ cc in every chamber.
When I asked Edelbrock what was goin on.....I was told the 60cc out of the box number was "nominal".
Go figure. [img]/phpBB/images/smiles/icon_frown.gif[/img]
<font color="red">***New Project***</font>'89 LX 408, SCAT crank &amp; H-beams, Probe pistons, AFR 205, Rawls SFT cam, Vic Jr intake, Pro Systems carb and more!!!
<font size=-1>[ This Message was edited by: mstngjoe on 1/30/06 7:29pm ]</font>
01-30-2006, 08:31 AM   #9 (permalink)
Nitmare67
Autolite 26 is crazy. The spark plug about 1/4 in the hole still. I run a pair of ported performer RPM heads on my 351 and when i check the autolite 26 before installing the heads the plug was still many threads from being all the way in. I ended up running 3926s. On a side not a buddy of mine told me to run 26's says that what he uses. After i showed him what was up with the plugs he changed plugs and it made a definate noticable gain in performance and response. Never knew how much gain a spark plug could bring
Nitmare67 is offline   Reply With Quote
