01-31-2006, 05:48 AM   #1 (permalink)
dablack
GT40 heads off of 96 explorer...how much lift will they take?
Ok guys, I about ready to start putting a 351 together. This is a buget build and I can't afford to change springs or put on better roller rockers. I've got a set of gt40 heads off of a 96 explorer. These are gt40, not gt40p.
I'm trying to pick out a cam so I need to know how much lift the stock springs can take?
Also, does anyone know the chamber size of the gt40s that came on 96 explorers?
thanks
Austin
dablack is offline   Reply With Quote
01-31-2006, 07:36 AM   #2 (permalink)
ckelly
Most of the GT-40's I've seen with stock springs need to stay under .5
01-31-2006, 07:54 AM   #3 (permalink)
dablack
Thanks ckelly.
Does anyone know the chamber size?
01-31-2006, 08:00 AM   #4 (permalink)
rkite
64cc
rkite is offline   Reply With Quote
01-31-2006, 08:06 AM   #5 (permalink)
frdnut
According to fletch's 5.0 site they are in the 59-61cc range.
01-31-2006, 09:15 AM   #6 (permalink)
rkite
That is for GT40P iron Heads.
GT40 iron Heads have a larger combustion chamber which ford says is 64cc.
You are looking at 9.0:1 compression with stock type flat top pistons.
This site says they are 65.6 cc -->
http://www.geocities.com/MotorCity/Pit/2740/heads.html
01-31-2006, 11:28 AM   #7 (permalink)
ckelly
64cc nominal, which to Ford means anything between 60 and 66. The ones on the Mustang are 61cc and have been cut to get there from 64cc (measured). If you get some, measure - don't guess.
01-31-2006, 11:38 AM   #8 (permalink)
dablack
So looks like if I use these heads on a zero decked 351W, w/ 22cc dish pistons I'm looking at
If chamber is 60cc then my compression would be 9.0:1
If chamber is 66cc then my compression would be 8.5:1
Like ckelly said, I need to messure.
02-01-2006, 11:27 AM   #9 (permalink)
frdnut
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>Whoops my mistake.I thought it was the "P" he was looking for. Guess I shoulda read a little closer.[img]/phpBB/images/smiles/icon_frown.gif[/img]
1968 mustang 306,stock ported heads,650 Holley DP,weiand xcellerator intake, Comp cams Magnum 292,244dur@050 and 518L,heddman headers,4speed with a 4.11 detroit locker.13.69 at 101 mph.
<font size=-1>[ This Message was edited by: frdnut on 2/2/06 2:28am ]</font>
