02-12-2006, 01:57 PM   #1 (permalink)
mc
AOD in park wants to lurch forward when revved up???!!!
Just put in a used aod behind my stock 289 and when in park at idle, it's fine. When I rev it up to 2500/3000 after a second the rpms will drop down 3/400 and the car wants to move forward. Is this tranny bad; something stuck or moving when it shouldn't. It sat for 7-8 years, but had only 50K when I bought it. Any advice on what to do?? THanks in advance. Chris
mc is offline   Reply With Quote
02-12-2006, 02:23 PM   #2 (permalink)
Stuarta
What in the blazes are you reving it that high for?
Stuarta is offline   Reply With Quote
02-12-2006, 07:11 PM   #3 (permalink)
retyler
That wasn't his question. Sounds like it's not going in park. Have you check your linkage?
02-12-2006, 08:19 PM   #4 (permalink)
1 Bad 88 GT
Maybe he's checking the total timing. Kinda like when I bounce mine off the 6K rpm chip in neutral, cause I can. [img]/phpBB/images/smiles/icon_rolleyes.gif[/img]
Back to the real Q. Do you have the TV cable attached? What kind of shifter are you using?
02-12-2006, 08:44 PM   #5 (permalink)
gork1rogues
If not linkage, it is most likely an internal problem. Last time I came across a car doing this the needle bearing under the forward drum hub shredded apart and metal was stuck between the clutches in that drum forcing the car to go forward.
02-12-2006, 08:55 PM   #6 (permalink)
1 Bad 88 GT
Since it sat for so long some dirt/foreign material might make the valvebody stick which along with the increased line pressure from the higher rpm could cause it to creep a bit.
02-13-2006, 07:59 PM   #7 (permalink)
mc
I think I'm going with 1badgt. I replaced my tranny, so TV rod was not affected or changed. In park at idle it's fine, but when revved up it does want to creep forward. How or can I go about fixing this problem? I put in new fluid along with filter/screen. Maybe the tranny's just to gummed up? Thanks in advance. Chris
02-13-2006, 08:05 PM   #8 (permalink)
1 Bad 88 GT
You might try removing the VB and flushing it out with solvent.
02-17-2006, 10:19 PM   #9 (permalink)
mc
Do you know if a 88 aod valve body will function/work properly when put in my 85 aod? Thanks, Chris
02-18-2006, 01:13 AM   #10 (permalink)
gork1rogues
It will function fine.
