02-28-2006, 09:33 AM   #11 (permalink)
dfree383
\'94 GT40 Heads on \'68 302
On 2006-02-27 13:44, dfree383 wrote:
Hang loose !!
Hopefully, the car will be tight and I'll be loose!
(Shaka bruddah, eh?!)
Way !!
02-28-2006, 11:26 AM   #12 (permalink)
greggieatthebat
Thanks for the info.... I guess I'm not as happy anymore. [img]/forums/images/smiles/icon_frown.gif[/img]
On 2006-02-28 08:29, ckelly wrote:
1) not unless you cut the heads for screw in studs.
At some of the online parts houses, the pushrods for "1980 F150 302" (which should be a flat-tappet, bolt-down-rocker engine, right?) are same length as the ones listed for my '68 302? Is this not correct?
2) assembled: set the engine to the intake centerline, put a dial indicator on the intake valve and compress with a fabricated lever. Note reading when valve contacts piston. Other - install clay on piston top, install head w/o gasket, use two solid lifters, cycle engine. Cut clay and measure clearance. On a stock motor up to about .512 lift you should not have ny problems.
This is the method I was going to use, but I didn't think of setting it at intake lobe centerline (duh). With 1.7 rockers I'll be at about .515", but I'm not sure if my pistons are taller or shorter than stock (or same size reliefs, or ?). Dad's looking for the info from when we bought the pistons back in '97.
3) heads flow better than the old stockers, I wouldn't waste my time porting to a Performer intake.
Yeah, these heads will flow a LOT better... but won't I do even better to get rid of that big step? Or is it not a big deal?
4) head gasket - use the stock 68 gasket (FepPro 1011-1 IIRC) and drill the four missing steam holes in the head to match the block - use the gasket as a template.
That is, on the head/block mating surface? Icky...
FRPP lists one engine gasket set (6003-A50) for 289/302/351W '63-'01? Does this have steam passage holes that are simply not used if you have a later block/head?
5) plug the EGR passage using 1/2" rod from the home store and some threaded plugs. The inserts are available from a local auto machine shop.
Sorry, I don't understand this; should I get 1/2" rod or should I get threaded plugs? Or just some bolts with thread locker?
greggieatthebat is offline   Reply With Quote
02-28-2006, 01:18 PM   #13 (permalink)
ckelly
Clarification:
Do some searching here on FM - you should find a lot of posts relating to the steam holes. I drilled 4 in each head. I believe if you don't and you run the GT40s on an early block, you will have overheating issues. Just line up the gasket, center punch, drill and suck out the fuzz with a shop vac - not a big deal.
On ours, I filled the EGR passages with steel rod and capped the ends with a small space filled with high temp silicone and threaded hex plugs. On the left side head, I used less rod and threaded in the reducer to accept the alternator mount. Your option, fill or just cap. I think the hex plugs look cleaner but you can stick whatever in there to close them off.
On the pushrods - I never checked, I had the heads cut for screw-in studs so we could transfer the existing valve train pieces over. The stock 302 pushrods that were in the motor are still in the motor and the geometry is close enough for this engine. If you're not cutting, get an adjustable pushrod and measure - you SHOULD be able to use anything from a 302 type engine that used the GT-40s because the deck is the same - IF the cam was a similar flat tappet.
02-28-2006, 01:45 PM   #14 (permalink)
greggieatthebat
Thanks for the clarifications!
On the rocker/pushrod issue, I know that the rocker set comes with shims to raise the rockers up to 0.090" (16 0.030 and 16 0.060 shims) off the head; I need to find out how to properly set the lifter preload, I guess?
02-28-2006, 08:53 PM   #15 (permalink)
ckelly
Check the FAQ on Crane's web site - they have some good notes. Basically, you're shooting for .020-.060.
03-01-2006, 10:15 AM   #16 (permalink)
greggieatthebat
Yup, got the rockers yesterday and there are good instructions in the box.
Early next week I'll get my head gasket set and do the swap; hopefully the pushrods are the right length, hopefully 1.7 is not too much!
Powerhouse products
