390 thunderbird
There may be some argument over fine points, but my opinion on 390's is listed below.
Your question has an answer that is based on what you mean by "build up".
If the engine is going to need pistons rings, bearings...in other words a full rebuild. Then it doesn't really matter which 390 engine you start out with. Except for a very few, very rare, solid lifter High performance 352/390's from early '59 to 60-61 and to a lesser degree 66-68 Mustang/FairLanes, most 390's are pretty much the same. Even those that were in pickup trucks and Mom 'n Pop grocery getters...by the time you change cams, manifolds and put headers on them...it really doesn't matter whether it started out as a 2-v, 4-v or better...you are going to throw away most of that stuff anyway.
So, when it comes down to push or shove, unless you are building a restored car, or freshening up an original; it doesn't matter. bottom line ... "Z" 390 motors are OK for something to swap in and keep for a while, but not anything extra special.
