vac. secondary holley carbs???
I'm curious...why do you need/want to do this?
If you just want to see or hear the secondaries open, while the car is NOT moving, you can use a screw in the slot for the secondary linkage. It will make it a positive link.
If you just want to hear them them open, take the air cleaner off temporarily, while in first or second...floor it anywhere after 2000 rpm, if you can hear it...then either your headers are open, you are running them loud flowmasters or you need a serious tune up [img]/forums/images/smiles/icon_wink.gif[/img]
but...in answer to your original request, locking or blocking the slot on the secondary butterfly will force the secondaries to open when the throttle is floored. It defeats the whole purpose of have a Vacuum secondary carberator...but it works.
