Trick Flow High Port \"Street Heats\"
You also may want to double check that your pistons will fit the new high ports, they should but best to check first. A new set of high ports should be ported for best results, summit sells them already cnc'd from TEA and they can handle a 393 and then some. Headers will most likey need to be custom....
