what happens if you run gas in a diesel?
Diesel in gas, 100% diesel will run S&$t if at all. The flash point, IE the degrees that the vapors will ignite is 165+ for diesel and -75 for gas. Diesel will smoke badly and fowl the plugs. However I knew a Highway Patrol that back in 72 he'd put 1 gal of diesel fuel to every tank fillup on his 71 429PI (429CJ) and it ran great. The diesel fuel lubed the valve stems better. Gas in a diesel will destroy it due to the combustion pressures being so different by the way the fuel burns. And that's only if it ignited. Gas requires a spark plug. Diesel is a control explosion when the fine mist of fuel is sprayed into the high pressure chamber.
