X303 Experiences???
nope you get into p/v issuse with the dur/overlap and no so much lift,the x is nit realy that much bigger than the b,now the z cam might have some issuse,the smaller the valve the more clearance you'll have,,hell ive got a stock 5.0L block 0 deck height,4-eye brow pistons,edel perf rpm heads,1.90/1.60, .565/.565 232/238 @.050 heads milled .025,just barely had to cut on the pistons,you def need to check either way
