07-05-2006, 07:35 AM   #1 (permalink)
Just Jim
Small Block Timing Covers and WaterPumps
Will a standard rotation v belt water pump work on a timing cover which originally had a serpentine belt set-up?This is on a '83(?) 302 which had a drivers side inlet water pump but I'd like to use a passenger side inlet v belt set-up.The front seal comes out the front,quite an improvement over the early covers which came out the back and required removal to change.
07-05-2006, 06:11 PM   #2 (permalink)
71LincMK3
I had no problems with that.Mostly when converting efi engines to carb for ol stangs.Used a el fuel pump then..
Olli
71LincMK3 is offline   Reply With Quote
07-07-2006, 07:32 PM   #3 (permalink)
quickshift
I recently had a similar question and after talking to ford tech,was told that it can be done IF you use a pump with a round hole instead of a pump wiith a "D" shaped hole,as this will cause a leak..........hope this helps.........MARK
quickshift is offline   Reply With Quote
Probe Industries
