07-13-2006, 08:55 PM   #1 (permalink)
347LX
How much h.p. can a stock 460 block handle???????
OK, all this talk of splitting 5.0'S,has got me ready to ditch my 347 and build a 460 for my galaxie.How much power can a stock 460 block handle?
347LX is offline   Reply With Quote
07-13-2006, 09:05 PM   #2 (permalink)
woody1
I have built half a dozen that made 600-700 at the crank, I know other guys above that. I always used D1 blocks, just happen to have them laying around so thats what I used
woody1 is offline   Reply With Quote
07-13-2006, 09:54 PM   #3 (permalink)
etcetera
I've seen quite a few with much more than 600-700. I've never heard of anyone breaking one either. Doesn't mean it can't happen, just not common.
Wait, I broke one. But it was 60 over and a cylinder wall split. It didn't split the block or break a main cap or anything like that. It happened on the way back from the muffler shop after installing cutoffs, which were uncorked. My buddy was with me and we were driving under this concrete bridge and I floored it and POP.
etcetera is offline   Reply With Quote
07-14-2006, 05:37 AM   #4 (permalink)
dacofa
I asked a machine shop machinist that quest once. He had a bunch of Ford, Mopar and Chevy big blocks in his shop at the same time and compared the caps of all three together. Checy was so small it was funny. Mopar was pretty beefy, but the 460's, he said unless you're putting a blower or running Daytona this weekend, you'll break something else before this Ford block breaks. Most braeks are due to something else and not any weakness in the BBF block.
07-14-2006, 06:34 AM   #5 (permalink)
347LX
Ok what about rods and cranks?
07-14-2006, 06:40 AM   #6 (permalink)
woody1
the stock rods are the problem, even the football rods with arp rod bolts, the rod typically breaks at the beam, I would definately suggest a scat h-beam for hp apps. I have seen numerous stock cranks on a well balanced motor take 8k+ rpm in pull trucks
07-14-2006, 11:07 AM   #7 (permalink)
dfree383
Stock Rods are considered good untill the 550-600 hp range. I have heard arguments the either design (football of Broach)is equal, when they fail it is in mid-lower beam not at the base where the beam meets the large end.
As for the blocks with stock 2 bolt caps the are good to the 800 hp range and installing 4 bolt caps I have heard of guys pushing the to well over 1000hp.
Stock cranks are pretty strong to the have large journals and alot of overlap and again I have heard 700-800 hp+
This assumes a clean and well tuned engine, a poor tune can destroy an engine at stock hp levels.
1991 LX Mustang 347 C4 combo 11's with the AC on.
1984 Mustang GT 460, Powerglide "Still putting it together" hoping for 9's !!
1929 T-Altered "In the works" 8's are on the horizon
<font size=-1>[ This Message was edited by: dfree383 on 7/15/06 2:08am ]</font>
<font size=-1>[ This Message was edited by: dfree383 on 7/15/06 2:10am ]</font>
07-14-2006, 12:37 PM   #8 (permalink)
tonys10sec306
small block
07-14-2006, 01:13 PM   #9 (permalink)
seefour
RAY WITHROW OUT OF TEXAS WHO BUILDS WRE CUSTOM RODS HAS RACED 460 'S FOR ALOT OF YEARS, HE SAID AT 800-850 IT WILL START TO PULL THE MAINS OUT OF THE BLOCK.I DONT KNOW IF THAT WOUKLD BE W OR W/OUT A MAIN GIRDLE.
MIKE S[img]/forums/images/smiles/icon_bow.gif[/img]
seefour is offline   Reply With Quote
07-14-2006, 01:33 PM   #10 (permalink)
dfree383
The girdles are only good for holding everything together when it splits !! They are pretty useless as you still only have 2 bolts holding the cap (They still Walk) the only effective way to solve the problem is to spread the load out (I.E. 4 bolt caps) and spread the stress over a larger area.
