The fact that it isn't disengaging the clutch sounds like there may be more to it than too much spring pressure.The only way to tell is have a buddy lay under the car and work the clutch pedal and see what is happening with the linkage...If it's not an adjustment issue I would suspect maybe the wrong release bearing or a bad pressure plate.
1968 mustang 306,stock ported heads,650 Holley DP,weiand Xcellerator intake, Comp cams Magnum 292,244dur@050 and 518L,heddman headers,4speed with a 4.11 detroit locker.13.69 at 101 mph.
<font size=-1>[ This Message was edited by: frdnut on 7/18/06 12:24am ]</font>
