holley idle
Smetimes the rear return spring for the secondries is tired or not installed from the factory with enough revolusions of spring around the throttle plate shaft, causing the secondary plates not to close all the time, or not close interminttantly.
Open and close the full assembly 10 times, and see if the secondaries return to the closed position every time ( withn the carb off the car...)
