Good shot admin - he's running a 2V intake and you told him to go buy a 4V carb. If he can't work a 2100, a nice fancy Ed won't help things any. Plus the problems with fuel line connections, linkage, etc. Brilliant suggestion.
Go back a read the instructions for the kit. The choke is not any more complicated than anything else on the carb. Make sure that the bimetal spring is engaged on the tang that connects the linkage to the choke plate - it's inside the black cup. Now turn the choke so the little mark on the housing lines up about two marks on the RICH side. That should close the plate. Check the choke plate opening at full throttle and adjust per the kit instructions.
You will need to set the fast idle to specs once you get it running. About 1500~2000, somewhere in there. It's common to have it running too fast if someone else messed with it to cover some other fault.
The copper tube that connects to the choke housing should come from a heat stove on the stock intake. You can repair it with any copper pipe of similar size. It pulls heat into the housing to warm the bimetal spring, which opens the choke plate.
It's worked well on millions of cars, no need to chunk it and go buy something else. If you prefer not to replumb the heat stove, then you'll need to hunt a choke housing with an electric bimetal spring.
After that, to start the car press the pedal to the floor twice and release, then crank. If the accel pump is working properly is will start right off. Check by holding the choke plate open and moving the linkage by hand - there should be a squirt from the pump nozzles just as soon as the linkage moves.
1967 Falcon 4 door w/351C - Owner built, owner abused.
70 Mustang 302 / 06 Ranger, 04 SuperCrew parts hauler
http://raceabilene.com/kelly/hotrod
<font size=-1>[ This Message was edited by: ckelly on 10/27/06 2:59am ]</font>
<font size=-1>[ This Message was edited by: ckelly on 10/27/06 3:03am ]</font>
