10-29-2006, 01:05 PM   #1 (permalink)
Big Bad Beater
Spot Weld Cutters
I'm going to be putting new quarters on my '65 Mustang...anybody know what size spot weld cutters to get? i don't like using drill bits so much on them...
Big Bad Beater is offline   Reply With Quote
10-29-2006, 01:59 PM   #2 (permalink)
FALCONAROUND
Spot Weld Cutters
Spot weld cutters are pretty much all the same size arent they... I've only seen one size....
10-29-2006, 05:55 PM   #3 (permalink)
Big Bad Beater
Spot Weld Cutters
Hmmm. I was looking online and there were several...I'll have to look at the welding supply store.
10-29-2006, 06:15 PM   #4 (permalink)
64 TBOLT
Spot Weld Cutters
http://buy1.snapon.com/catalog/tools...e=snapon-store
10-29-2006, 06:16 PM   #5 (permalink)
n2omike
Spot Weld Cutters
Pilot point drill bits work just as well, are easier to find and are less expensive. [img]/forums/images/smiles/icon_wink.gif[/img]
10-29-2006, 07:28 PM   #6 (permalink)
igo1090
Spot Weld Cutters
try eastwood.com
igo1090 is offline   Reply With Quote
10-30-2006, 07:08 AM   #7 (permalink)
Big Bad Beater
Spot Weld Cutters
Thanks for the tips all!
10-30-2006, 09:02 AM   #8 (permalink)
wcj56
Spot Weld Cutters
Don't waste your money. Unless you buy the $50 ones they are junk. I bought the ones that have replaceable bits and broke the first one on the second hole. They do come in 5/16", 3/8", and 1/2". Usually 3/8" will do it but I also found several that had been double shot. Like N2OMike said pilot drill bits are much the same and dont break near as easily. A 3/8" hole saw will also work but not as easy to find.
wcj56 is offline   Reply With Quote
10-30-2006, 04:28 PM   #9 (permalink)
bonfire
Spot Weld Cutters
I like the blair spot weld cutter in 3/8". The trick to using them so you dont break the cutter is to drill a small pilot area or to use a punch to make a divot for the retractable point to rest in. The cutters break when they skip around.
Bill
bonfire is offline   Reply With Quote
10-30-2006, 04:54 PM   #10 (permalink)
n2omike
Spot Weld Cutters
I'm telling you, guys.... A 3/8" or 7/16" pilot point drill bit costs around $5, and will work just as well if not better. Give one a shot.
