68 turn signal switch
So I need to replace my turn signal switch, it's not working properly. What irritates me though is that I had this done by a shop about two years ago. Only about a month after I had it replaced the switch started to be really stiff when using the turn signal lever. It was more stiff raising the lever for a right turn. A little later I felt something break, and when making a right turn I have to actually hold the signal lever up while I am making the turn otherwise the signal lever won't stay up and will stop signalling. Also the left turn signal stopped cancelling. Today I took the steering wheel off and noticed a few of the plastic pieces in the switch were broken off. Anyways.... now I am going to replace the switch myself, but I want to avoid having it break after the first month like last time. Are there any special ways the switch is supposed to be aligned or adjusted when it's installed? I have never done this before so what are the steps? Any tips you guys have would be great. Thanks!!!
John
