11-15-2006, 10:13 AM   #1 (permalink)
frdnut
What\'s a good head for a 393/408 windsor?
If I go with a 393/408 what is a good cylinder head?..I want to just be able to bolt it on and go and not have to worry about headers fitting or porting etc...I'm just looking for a strong street motor(450-500hp) that will see the occasional strip pass.
11-15-2006, 10:37 AM   #2 (permalink)
econodrag
afr 225
econodrag is offline   Reply With Quote
11-15-2006, 01:16 PM   #3 (permalink)
jasonn
The afr 225's are an awesome head. But if you are looking to make 450-500 the vic jr's will be PLENTY. I have only 10-1 compression, with a small mild hyd roller, 1 5/8 headers, dual plane intake, and mine made 519hp. Headers bolt right up and they were only like $1300. I think these are a very good bang for the buck.
jasonn is offline   Reply With Quote
11-15-2006, 04:31 PM   #4 (permalink)
smokey212
If you want to keep around 500 or so HP go with the 205's. I built a 414 with the 205's and a .600 lift cam, which is relativly small for those heads and made 535 at the flywheel. That's with a dual plane stealth intake and a 750 bigs carb. I could have easly pushed the 600hp mark with a bigger cam and single plane race intake.
smokey212 is offline   Reply With Quote
11-15-2006, 05:45 PM   #5 (permalink)
Cain
Since you are building a street stroker, I'd say go with some AFR 205's or some of these http://www.livernoismotorsports.com/...t.phtml?p=1471
That being said, if (more like when) I build another windsor stroker, it will have some AFR 225's.
Cain is offline   Reply With Quote
11-15-2006, 06:14 PM   #6 (permalink)
strokerman
i think the 205s will work better with header fit.
strokerman is offline   Reply With Quote
11-15-2006, 06:43 PM   #7 (permalink)
ujt389
Id go with some Victor Jr.s
11-15-2006, 06:57 PM   #8 (permalink)
tbirdz12
I got 185s and should be at 500+ with a 392, RPM Air Gap and 750 SD.
The 185's will get the job done. Im not say the 205's wont make more, just saying the 185's are a great head for that combo.
Heres some articles on the 185's from the AFR site.
536 HP with 185's, 392 and single plane and 750 SD
http://airflowresearch.com/articles/...024/A24-P1.htm
525 ± HP 408 with 185's
http://airflowresearch.com/articles/article061/A-P1.htm
497 HP 427 with 205's Mass Air
http://airflowresearch.com/articles/article116/A-P1.htm
522 HP 408 with 205's Single Plane
http://airflowresearch.com/articles/article112/A-P1.htm
tbirdz12 is offline   Reply With Quote
11-15-2006, 07:10 PM   #9 (permalink)
smokey212
I"m saying if you want to keep that thing were it is a pleasure to drive on the street, I would go with the 205 or maybe even the 185's. My car is at its max as far as streetablity goes. I have a t5 with 389 gears. It doesn't come alive until abot 3000 rpm, and it's fun from there to 6800 rpm. But down low you can tell the car is running really inefficent. So make sure you plan well for what you going to be using the car for before you spend a bunch of money.
11-15-2006, 07:14 PM   #10 (permalink)
qtrhors
I like the vic jr for the "mild" combo(like 500 hp is mild). Great bang for the buck out of the box and major potential.
qtrhors is offline   Reply With Quote
